AirPort Board
2 Answers 1 Score |
How do I fix colored lines down my screen caused by pressure? |
9 Answers 27 Score |
Battery percentage suddenly drops from ~60% to 7% |
30 Answers 17 Score |
Why did my internal keyboard and mouse suddenly stopped working? |
6 Answers 6 Score |
Change of RAM possible? |
Documents
Parts
- Apple MagSafe 2 AC Adapter
- MacBook Pro Retina (2012-2015) Lower Case Screw Set
- 2.5" Hard Drive Enclosure with USB 3.0 Cable
- MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet
- MacBook Pro 13" Retina (Late 2012-Early 2013) Battery
- MacBook Air (A1369, A1466) MacBook Pro (A1425, A1502, A1398) Key Caps
- MacBook Pro Retina (A1425, A1502, and A1398) Lower Case Screw and Foot Kit
- MacBook Pro Retina (2012-2015) Display LVDS Cable
Tools
- Spudger
- Tweezers
- iFixit Opening Tool
- Phillips #00 Screwdriver
- iFixit Thermal Paste
- TR8 Torx Security Screwdriver
- iFixit Adhesive Remover
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- Heat Gun
- T5 Torx Screwdriver
- Phillips #000 Screwdriver
- T6 Torx Screwdriver
- Adhesive Cleanup Kit (Set of 12)
- Utility Scissors
- Arctic Silver ArctiClean
Models
A1425 (EMC 2557 MacBookPro10,2) 2.5 GHz, A1425 (EMC 2557 MacBookPro10,2) 2.9 GHz
The MacBook Pro 13" with Retina Display was released October 23, 2012.
Identification and Background
Unlike previous iterations of MacBook Pro, the MacBook Pro 13" with Retina Display is not labeled "MacBook Pro" on the bezel. It can instead be identified by its label on the bottom of the computer along with the model number A1425.
The MacBook Pro 13" with Retina Display is thinner than non-Retina MacBook Pros, but slightly thicker than the 15" MacBook Pro with Retina Display. It has two USB 3.0 ports, one on either side of the machine, two Thunderbolt ports, and a MagSafe 2 power adapter. This model also includes an SD card reader and an HDMI port.
Technical Specs
Display:
- Retina display: 13.3-inch (diagonal) LED-backlit display with IPS technology; 2560-by-1600 resolution at 227 pixels per inch with support for millions of colors
Storage:
- 128GB, 256GB, 512GB, or 768GB Flash Storage
Processor:
- 2.5 GHz Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache
Memory:
- 8 GB 1600MHz DDR3L onboard memory
Wireless Connectivity:
- 802.11n Wi-Fi wireless networking;3 IEEE 802.11a/b/g compatible
- Bluetooth 4.0 wireless technology
Graphics and Video:
- Intel HD Graphics 4000
- Thunderbolt digital video output
- 720p FaceTime HD camera
Battery:
- Built-in 74-watt-hour lithium-polymer battery
Ports:
- Two USB 3 ports (up to 5 Gbps)
- Two Thunderbolt ports (up to 10 Gbps)
- MagSafe 2 power port
- SD card slot
- HDMI
- Headphone jack
Dimensions:
- Height: 0.75 inches (1.9 cm)
- Width: 12.35 inches (31.4 cm)
- Depth: 8.62 inches (21.9 cm)
- Weight: 3.57 pounds (1.62 kg)
Additional Links
Apple's Product Page
MacBook Pro (Retina, 13-inch, Late 2012–Early 2015) Service Manual
